| Автор | Сообщение |
		| amigo_0071 |
				|  Заголовок сообщения: Alfa Romeo 166 - 2.4JTD - не работают задние противотуманки   Добавлено:  12 ноя 2015, 17:50  |  |
			|  |  | новичок |  |  |
				| Не работает задние противотуманные фары. Предохранители все вроде целые, может еще где есть где я не знаю, и жгут проводов что идут от крышки багажника в салон перекрутил но результата не добился. Может подскажет кто в чем причина где проблему искать?
		| subsan |
				|  Заголовок сообщения: Re: "Alfa Romeo 166   2.4 JTD   Добавлено:  12 ноя 2015, 19:48  |  |
			|  |  | новичок |
 Авто: AR166 2.0TS
				| Вот что нашёл в eLearn'е по задним противотуманкам (местонахождение узлов и wiring diagram):   и описание: Код: The main beams are controlled by electronic Check device M45 , that receives control signals from the switches and controls the bulbs while also checking the various lines.
 Check device M45 is supplied directly from the battery. (maxifuse CENTR of B5 ) to pins 1 and 6 of connector C, via fuse F11 of junction unit B1 .
 An ignition-operated power supply (INT/A) reaches pin 9 of connector C through fuse F1 of junction unit B1 : pin 7 of connector C is earthed.
 The device M45 receives as an input the signal for rear fog lamps switched on by the button located in unit H35 - pin 10 of connector A; this signal only arrives if the side lights are on. If, in addition to this signal, there is also the dipped beam headlamps on signal - pin 6 of connector B - or front fog lamps on signal - pin 2 of connector A, the device M45 then sends the supply to the rear fog lamps in the central rear lights clusters F35 (left) and F36 (right), from pin 10 and pin 4 respectively of connector E of M45 .
 At the same time, a signal is sent from pin 3 of connector B to the unit H35 to light up the LED near the button indicating the 'rear fog lamps on' function.
 The supply for this LED for H35 is controlled by the ignition (INT/A) via fuse F5 of junction unit B1 ; this line allows the control panel H35 to be lit up when controlled by the ignition (INT/A).
 The device M45 checks the efficiency of the bulbs and their connections: if faults are detected in the circuit, the 'lights fault' warning light on the instrument panel E50, pin 7 of connector C, is lit from pin 6 of connector A, while pin 15 of connector A supplies an ignition-operated power supply to the panel through fuse F1 of the junction unit B1 .
		| Victor |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  15 ноя 2015, 16:02  |  |
			|  |  | Альфист |  |  |
				| Просто для ознакомления скажу что задние птф включаются после передних,тоесть включаем передние птф а затем только задние.
		| sasha_80 |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  15 ноя 2015, 22:11  |  |
			|  |  | Альфист |  |  |
				| Victor писал(а): Просто для ознакомления скажу что задние птф включаются после передних,тоесть включаем передние птф а затем только задние. бред. туманки задние и передние работают не зависимо друг от друга. По сему и кнопки разные. И пофиг как их включать._________________
		| sasha_80 |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  15 ноя 2015, 22:14  |  |
			|  |  | Альфист |  |  |
				| amigo_0071 писал(а): Не работает задние противотуманные фары. Предохранители все вроде целые, может еще где есть где я не знаю, и жгут проводов что идут от крышки багажника в салон перекрутил но результата не добился. Может подскажет кто в чем причина где проблему искать?   как раз ищи в жгуте проводов. частая болька у 166. полностью сними жгут к крышки и сними резиновый гофрированный кожух. Сам все увидишь._________________
		| subsan |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  16 ноя 2015, 11:28  |  |
			|  |  | новичок |
 Авто: AR166 2.0TS
				| Victor писал(а): Просто для ознакомления скажу что задние птф включаются после передних,тоесть включаем передние птф а затем только задние.    та как-то вроде нет... у меня включаются отдельно и независимо... а вот для ознакомления сказал-бы, что без хотя-бы габаритов не включатся
		| subsan |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  16 ноя 2015, 11:29  |  |
			|  |  | новичок |
 Авто: AR166 2.0TS
				| sasha_80 писал(а): amigo_0071 писал(а): Не работает задние противотуманные фары. Предохранители все вроде целые, может еще где есть где я не знаю, и жгут проводов что идут от крышки багажника в салон перекрутил но результата не добился. Может подскажет кто в чем причина где проблему искать?   как раз ищи в жгуте проводов. частая болька у 166. полностью сними жгут к крышки и сними резиновый гофрированный кожух. Сам все увидишь.так-же к этому склонялся бы... вот в соседней ветке http://www.alfisti.by/forum/viewtopic.php?f=8&t=3114  снизу кинул фотки что у меня было со жгутом...
		| amigo_0071 |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  17 ноя 2015, 19:21  |  |
			|  |  | новичок |  |  |
				| Вот еще что заметил когда передние противотуманки включаешь слышна что счелкает реле, может и на задние реле то же должно же быть... Где они находятся подскажет кто?
		| Автобот |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  09 май 2020, 10:35  |  |
			|  |  | новичок |
				| Парни отзавитесь , проблема нарисовалась, в 166 2.4 JTD 99год, не горит задняя левая противотуманка, шлейф целый не переломан прозвонил,может есть у кого картинка схемы подключения задних противотуманок на 166 99 года дайте плиз.
		| Автобот |
				|  Заголовок сообщения: Re: Alfa Romeo 166 - 2.4JTD - не работают задние противотума   Добавлено:  10 фев 2021, 17:11  |  |
			|  |  | новичок |
				| Скоро как год писал в теме и никто даже не ответил, да ладно, сам разобрался во всей электрике альфы, полностью изучил и перебрал все схемы. Суть моей проблемы было в том что не горел задний левый противотуманный фанарь. Проверив и прозвонив соединения от фаноря до блока освещения обнаружил что нет выхода с блока, вскрыв блок видим много мощных полевых транзисторов, которыы отвечает именно за лампочку противотуманки вычисляем визуально по дорожкам и прозванивая.Таких теперь не выпускают но есть заменители по 1.5 б.р. на рынке в минске, перепаиваю транзистор и всё работает.Если нужен совет по электрике пишите подскажу.
